I need the smartest person here!
My HP200i recognizes DVD+Rs as simple 700Mb CD-Rs. I have no problems with DVD+RWs. I can write and rewrite them since day 1.
I tryed to upgrade the firmware, didn`t help.
Now what to do?![]()
Nero 5.5.8.2.
When I see the drive propertis at My computer with the DVD+R in it, it looks like it`s a CD-R. -
get the new version. I had same problem with some discs, got new patch, and it fixed it.
Originally Posted by hedo26
Nero medium properties says
DVD-session
DVD+R
total capacity: 0mb
available capacity: 0mb
When I try to write something on it /less than 4.37gb/ it says there is not enough space on it. I can write the same movie on DVD+RW! -
I have a 200 external but let me take a stab at it.
First....upgrade the nero to the latest version.
Second...and I don't know if this is what you are trying to do ..... and this still hapens.....don't try burning an image file to dvd with nero....it automatically defaults to thinking its burning a cd and gives the same message......try burning iso's with dvddecryptor. -
I have the exact burner you have, and it works fine and recognizes everything. I didn't even update the firmware. The media I've used so far is Fuji Film DVD+R and HP's DVD+R. BTW, I've used Easy CD Creator 6 and Copy2DVD as my burning programs.
Apple's DVD-player doesn't seem to get along with Toast DVD-menus
By HitTheRoad in forum MacReplies: 12Last Post: 11th Aug 2011, 03:24 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
NEC ND-3500AG DVD RW DL burner doesn't recognize blank DVD's
By renegade431 in forum DVD & Blu-ray WritersReplies: 38Last Post: 8th Feb 2009, 06:16 -
DVD copying with Nero - demands DVD/RW disc and still doesn't work.
By gorelle in forum Newbie / General discussionsReplies: 4Last Post: 5th Apr 2008, 04:44 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58
